Propane Injection - Hidden Injection Point?
  • Yes!
    Votes: 25 75.8%
  • No!
    Votes: 4 12.1%
  • Huh?!
    Votes: 4 12.1%
  • Total voters
    33
Are you reffering to the BOP on 27,28,29th. If so great Ill be there I would like to check this out for both my sy and gn
What does the tank look like i.e. gas grill, can you mount it horizontally or vertical, also could use a diiferent type of tank
It looks like a shrunk down gas grill tank. The mount we supply holds the bottle in an upright position. That's the only way we have tested so I don't know what to tell you about other positions.
Far as using another gas, I have no idea. We tested it with propane so that's all I know that I can say for sure it works with.
Can you use a Nitrous bottle to hold the propane instead of the tank? Would this work? How big is the tank that is used with this kit?
I seriously doubt you will find anyone willing to put propane in a non propane approved cannister.
The tank we are using is about 12 x 8
