Need Help...........
ok....kit is installed....i tuned for about an hour....i got the biggest jet that was supplied stuck in there...i think its a 92 or something?..anyways, im getting about 2 degrees knock at 20 psi with Reds 93 chip in.....of course i dont really know how to play with this thing yet since i speed read the tuning instructions...i plan on rereading them tonight. Any other suggestions? Heck i dont even know what the gauges on the regulator are ....my guess is whats left in the tank is what its reading.......also, what is the knob on the regulator for that has the propain sticker on it?
....anyways, back to the directions
BTW, heres the combo:
Balanced and Blueprinted 3.8 Liter V-6
TTA Crank
.020 Bored Block
JE Forged Pistons
Comp 206/206 Billet Roller Cam
Champion Heads 1.77 Intake 1.55 Exhaust - Stainless Manley Valves
Champion - Lower Intake (port matched)
Upper Intake - Jay Jackson ported, EGR removed
55lb Siemans Injectors - Modified ECM with Reds 93 and 107 chips
John Craig TE45a turbo
CAS V4 Stretch Intercooler
Terry Houston 3" Down Pipe with cutout (ceramic coated)
Hooker 2 1/2" cat-back exhaust (ceramic coated)
ATR Blow Off Valve
8.5mm Kenney Bell Plug Wires
Kenney Bell Ram Air (no canister) with a 9" K&N
Red Armstrong Volt Booster
Adjustable Fuel Pressure Regulator
ALL BILLET 9X11 3600 Stall - PTS Converter
Performance Transmissions Killer Street/Strip Transmission
Moroso Line Loc
Fan, Fuel, and Converter Lockup Switchs
26x10X15 ET Drags mounted on 15X8 Pro Star Wheels<---need bigger slicks
Scanmaster II, Direct Scan
Fuel Pressure, Boost, EGT, Air/Fuel Mixture, and Oil Pressure Gauges
Dual Air Bags in rear springs
Competition Engineering 3-Way adjustable shocks 60/40 rear 80/20 front
ATR rear sway bar
HRPartsnStuff Lower Control Arms
Poly Urethane Bushings in suspension
Electric Cutout
Propane Injection System
Mobile 1 Synthetic 15W50 since day 1
TTA Crank
.020 Bored Block
JE Forged Pistons
ATR Blow Off Valve
Moroso Line Loc
ATR rear sway bar
Electric Cutout
