Proper stall convertor for setup
VADER
Little engine that could
Tranny is leaking, thought I might consider replacing the convertor. Right now its 3500 stall Precision non lock up. I havent checked where the leak is, its a big one though. I think it only leaked in drive, not sure. Also need a driveshaft loop.
Any recommendations? Diff stall, brand, lock up?
My set up is in sig. Thanks.
911 lockup, About 3000-3100 unless you think you might go with a bigger turbo later.. if thats the case, I'd stay with 3500.
