Pros and Cons of a th350
GNguy
U aint that big
Well, I am thinking of going with a built th350 transmission, what is your take on this trans? Is it as good or better than the 200r4? the transmission can handle upwards of 700 horses....thanks for any info.
they are supposed to be pretty stout, i took the one out of my car that came with it because I wanted the extra gear for the highway. You will probably have to run a mechanical modulator, as the vacuum modulator doesnt work under boost, not sure if you can just run a check valve or not. The transmissions are the same length but I had to use a different crossmember when switching back to stock.
