The only full pass I made since I switched, it went 10.60 @ 128. That was letting the car shift 1-2 auto, me shifting 2-3. It shifted at 4800 to second, I shifted to third at 5900. So theres's no real data there cause of the short shift.
Now I can tell you it went from crossing the line in BG at 6100, on the last pass it crossed at 5450. But again that was 1000rpm less in first gear, which I would think should effect my rpm in third.
At 22psi of boost I'm seeing almost 1100 rpm drop, I'm sure I will lose some drop when I turn the boost up some more. The 10" was dropping 450 rpm, you couldn't hardly see it on the graph.
