I would be sure to OVER drill the flexplate holes so there is room move the bolt to get it into the converter hole. Test fit the location of the holes on the flexplate with the converter to be sure they line up, you may have to drill a hole into an ellipse to allow stright line access of the bolt to the converter hole. If you don't drill the holes you will have trouble threading in the bolts to the converter. I had to drill and drill and drill even though I test fit the bolts through the holes before hand. They fit in the holes but my holes did not line up so I made for alot of extra work. I should have test fit the converter first.
Even though its more work, it is well worth it when you feel the difference the PTC non lock up makes. I have two cars with this converter.
