blackgn231
Money pit
- Mar 28, 2007
I just put mine on and have a plenum spacer under my throttle body well I did a check to see just how close the pipe was to the hood pad by putting some grease on the top of the pipe and shutting the hood. There was some transfer on to the hood pad so 2 questions? Has anyone had this same problem with their PTE fmic and does this plenum spacer really work?Or is the power plate the way to go?I have seen cars with a PTE fmic with a spacer but no sign of rubbing ,It could be just touching and may not do anything but just wanted to see if anyone else has had this set up in their car?
