I'm looking to do a turbo swap replacing my PTE6152 JB with the new PTE 6266 SP CEA Dual ball bearing turbo. Has anybody run this turbo on the street yet? any isseus controlling boost creep??? MY current set-up is an external waste gate in the cross over pipe driver side. Looking for feedback on how guy's are controlling boost with these new CEA wheels???
Hope my converter will spool this 6266dbb without issues...
my curent combo:
109 block-@ billet mains stock crank/rods/pistons
Max ported big valve Irons
218/224 billet roller cam-1.65 Roller Rockers
70MM TB/Plenum
PTE Front Mount IC
3" THDP-dual Pypes 2-1/2" exhaust
80 Lbs injectors from Turbo tweak-WB Chip, MAF tanslator ,85mmMaf Sensor, MH Big Mouth 4" cold air intake
XP Fuel Pump
Julio's ALky kit-single nozzle
Art Carr 16930 9' Converter-I believe the stall is near 3000-3200
My car spools pretty fast now and is a street car that will see the strip maybe 3-4 times/yr. I want to upgrade to the new CAE Dual ball bearing unit but my concern is it could spool slower with the bigger turbo even with ball bearing tech...any one have this turbo or the 6262CEA on their setup that can give feedback???
my curent combo:
70MM TB/Plenum
PTE Front Mount IC
XP Fuel Pump
