PTS Shift kit install help
jmidolo
Sexy MF Joe
Bruce, I'm sure you'll see this anyways, figured I'd post it here and let you read it at your leisure rather than tie you up at the shop during the day.
Do you have or anyone else on here have any digital pics of the shift kit install? I've got no prob droping the pan and vb, but not quite sure of which part of the vb needs to come apart from the photocopy instructions...
Pictures worth a 1000 words :)
Call the shop..
Mark will walk you thru it. It is pretty simple really.... :D
Bruce
WE4
You're a busy guy and hard to get ahold of :)
I've got a few questions on the shift kit install... Most of them are on the check balls and the size of them, how do I know what size to use where?
Also, I had a few on the vb mods as well.
Also, there were 3 bolts in the kit...look like TC bolts..what are those for??
The seperator plate...is that different than the one in my car or just a New GM one...can I just use my Orig, or should I use this one if different?
Check ball locations, directions are tough to tell, which are in the VB, and which are above the seperator plate, and which size is what?
I need a TCC selanoid too, should I get one from a 700 and I've heard it needs to be shimmed?
Last one I think :) One one part of the directions, it says, put spring C in here, then take this spring and put it over there....well, over there...is there gonna be a spring in there that I am replacing, or adding the one from "here" to there??
I got your email
will wait for your call. Talk at you later
BT
WE4
