Pts Shift Kit Install
rpk250
member
Just installed PTS shift kit and went for a ride. Trans is shifting very high, 3500-4000 rpms even at part throttle, and shifts are very hard. Hard enough to pop my glovebox open. Anybody have an idea about what I did wrong?
I don't know a whole lot about transmissions, (I'm here to post my own shift kit question), but if I understand correctly, the downshift cable, or TV(?) cable adjustment can cause problems like this. Hope that helps, Jim.:)
TV cable
Adjust it to stock length, ie... pull it all the way to the firewall, push the gas pedel to the floor. May have to adjust it one or two notches to fine tune it. I'm sure Bruce will chime in to give you more info.
HTH, CaptRob
RPK, try adjusting the TV cable first. If you still have an issue, give us a call.
thanks, Mark
