I pulled my motor out today for head swap, timing chain and rear main seal. Unbolted the heads and it took almost exactly 65 ftlbs to break the bolts free. Stock Head gaskets looked like they were sealing perfectly. Heads were 100% stock and unmodified in anyway, so 118 mph with a TA49 and bluetops doesn't require any motor mods.
Since I try not to make it a habit to tear these things apart, I have questions about the look of the cylinders, pistons, etc:
The pistons have a slight dish and have a rough texture on them. I'm guessing it deposites of some sort or the piston tops melting
is this normal?
The cylinder bores have a smooth feel, but are dull in appearance and are "dry" rather than oily. Is that normal?
when the piston is down in the bore, I can see a lot of ring. I mean a lot of ring, like 1/16th of an inch around the piston. Is that normal? The rings are shiny and the pistons are dull so maybe I notice them more, but it still looks weird to me.
Thanks for the help.
