Sal Lubrano
- Apr 26, 2002
Does this pump look like it can be used or is it trash? I ran some scotch brite on it to accent the wear marks. It looks perfect except for one section. There seems to be a ring around the center of the wear surface which I can catch with my finger nail. It can be seen in both halves of the pump. The secition with the stator support it does not even go all the way around the ring. Will this effect the pressures or pump failure?
