I maybe in need of some bigger boost valves,a new PR spring,and new pump slide springs. I am having some issues with my pump.
I used the sonnax O ring .500 and .283 reverse boost valves. My pump is making a noise that sounds like rocks in Rev,2nd,1st. I also noticed a flare in 2nd as it comes past 12-14 psi. I had a regular .500,.296 rev boost in it before. It was working fine before,should've left it alone.
This last build I went with a billet drum,dual feed. Other than that It was just new clutches/band/low rev sprag.
My pressures are
Min Max
P 80 200-220
R125-100 bounces badly 175-225
N 80 200-220
D 80 205-215
3 80 205-215
2 175-195 NO Change @max
1 160-185 pulses and dips to 125 intermitantly
Pump is not scored,10 vein with new rings veins on the last build 5k ago. Everything was wet sanded flat and deburred.
Not sure where I went wrong..LOL...I am determined to beat this thing
My pressures are
Min Max
P 80 200-220
N 80 200-220
D 80 205-215
3 80 205-215
