I am piecing together a DIY kit and locally I can buy a 2.2 GPM 200 PSI pump cheaper than the normal ShurFlow pump. Does anyone know if there is a reason to go with the smaller pump?
It is a Shurflo, it is just a higher PSI pump made by them and for some reason locally it is a lot cheaper than the 2687 everyone is using.
I wasn’t sure if the PSI was too high for alcohol. I would buy the 2687 but if I get it from a local supplier and there is a problem I can exchange it were I got it.
I have all the info at work, not with me, but I will send the specs to you tomarrow. If you are buying over the internet I am sure it is cheaper for you to do it that way. The dealer here wanted $148.00 for the 2687.
