Rosey1968
 - Mar 31, 2017
So I am trying to check my fuel pump voltage...  I dropped the tank to inspect everything so the tank is out of the car.
I do have a Racetronic hotwire kit from 2011... which wire is the correct one? This is the plug into my fuel sending unit:
The purple wire in 8.6 with key on, engine off. this seems low... is it due to a lack of a solid ground? I was grounding to the grounding strap that is attached to the body and take (when in the car).
The hot/red wire at that goes into the Hot Wire relay is 12.6 with the key on, engine off.
Any advice woudl be apprecaited.
Thanks.
Thanks.
