Scott89TTA
- Jul 12, 2005
A friend of my son put together a Dyno Day this past Sunday. They needed some more cars so they asked me and some of my buddy's to come as well. Turned out the word got around and they had plenty so it ended up costing us $40 each for 3 pulls. Couldn't pass it up even if the car wasn't running its best.
First off...my TTA is stock except for Grumpy's MAF pipe and a K&N. I just added an adjustable waste gate actuator and installed new plugs. The car definitely runs better then it did but still needs new plug wires...they are at home waiting to be installed. At least one of them will arc if you get anything near it so I'm sure the others are close or just as bad. My car needs the typical Spring cleaning as I know there is some oil in the IC as well. On my Dyno plot I am guessing that either my plug wires and or valve springs are killing power above 3800 rpm since the hp slowly falls off and the torque falls off pretty fast after 3700 rpm. I guess the best thing is my air fuel ratio is pretty solid right around 12.
Am I on track with my assumptions or is my plot normal or am I way off
Here's my plot...
Here's my plot...
