85begalttype
just a v6
- Oct 22, 2008
im going to be installing the front cover, intake manifold, oil pan, heads, valve covers etc.. i know not to use gasket sealer on the head gaskets,
Intake manifold - waters passages? on both the head and manifold side of the gasket?
valve covers - ive got the rubber fel pro gaskets, should i use sealer on the valve cover side so the gasket sticks and easier to install
timing cover - install dry or i bit of sealant on which side of the gasket?
oil pan - i got the thick cork gasket and i was told this was best to install dry
