87Silver Bullet
- Feb 17, 2005
Looking for a little help with a Quad Air Voltage Booster wiring question. I am just putting the finishing touches on a 87 T Type I bought with a popped motor.
After hooking up all the sensors and vacuum lines, I have one wire left over. There is a relay mounted on the driver side inner fender which has one wire that runs to the fuel pump, one wire runs to an inline fuse then to the stud on the alternator. The mystery wire is white, long enough to reach the alternator and has a 1/4" male spade terminal on the end of it. The only thing that is close by is a green conneter with a single wire in it, this is part of the factory harness. If that's where the white wire goes, what does that wire in the green connector go to?
Thanks in advance for the help.
Mike
Mike
