According to Summit's catalog the 345/35-R18's are almost 2 inches wider on the tread. 1.8 inches to be exact. I'm looking for that +/- 2 inches.
From Mickey Thompson's web site:
Size Weight Measuring Rim Section Width Tread Width Diameter
P325/50R15 32 lbs. 10" 13.2" 11.6" 27.8"
P345/35R18 35 lbs. 12" 13.9" 12.8" 27.5"
The section width (width from inner sidewall to outer sidewall) is more important than tread width if you're going for "look". And the difference is .7" or 18mm...exactly as would be expected.
Not trying to piss on your cornflakes. Just trying to make sure you understand what you're going to wind up with after all that time and money.
PS - Sorry, but this site won't allow you to post tables and I'm too lazy to post a .pdf. All the info is there though.
