question about my 3rd gear shift.
peterkin
..it isn't rocket science
my transmission was built last year and since then my third gear shift has softened up considerably at full throttle. at part throttle it will almost chirp the tires, but at full it's like the tranny slides in gear. when i first start the car up and let it warm up the first couple third gear shifts are hard, then they kinda soften up. is this something i need to get checked out before i buy a 9 inch converter? i really don't need to be worrying about a tranny right now. what would cause this and is it an easy way to get my firm third gear back.
the one thing i haven't done since having it built is have the fluid changed yet. i'm going to have that done when i get back from north carolina this weekend. the tranny has about 6k miles on it since the rebuild. is that to many miles on it before a fluid change? will the fluid change help the third gear shift?
oh, no the fluid isn't burnt nor does it smell burnt. it's fine. i kinda had a feeling i would be asked that.
inproper factory calibration is the main cause of this problem and it is mainly a miscommunication w/ the accumulator valve.try installing one from a 89 and up 700r4 valve body(code a) with your 2004r line bias spring on the valve .or you can order our recalibration kit .www.ckperformance.com
mike, i didn't do anything and i couldn't tell you what andy did to my tranny when he built it. i could ask him. sorry so late on the reply, i was down your way for the weekend to get my jeep out of the body shop.
chris, i'll research the recalibration kit more. is that a known problem, or is anyone else that you know having the same problem.
chris, i didn't see a recalibration kit on your site. is it called something else, or specifically that.
CALL US FOR THE INFO THERE ARE SOME STUFF THE CLOWNS DIDNT PUT UP YET7186264315
