cottonpicker14
- Feb 17, 2005
I decided to clean and wax the bottom of the driver and passenger doors. I found that there was two rubber plugs on each of the doors at underneath.
To me it seems that these should be removed because if water gets into the door by way of the top of the door and glass, it would get trapped inside the door because of the plugs.
Can anyone check the bottom of their doors to see if these plugs were removed ? YOu will have to lay on your back on the ground to see them.
Thanks.
Thanks.
