hi razor
razor , i'm having an issue with the power distribution block
( the one that's strapped over the steering column) i had freddy test it and it has power going in but not coming out, is there a fuse in or behind that box?
I see that the new ones don't even bring that box anymore? if it does not have a fuse could i make a bridge in order to bring power to the control box ( the box were you set the alcohol level) if i do that will i damage anything? i have not done anything yet, i'd rather ask you first before i make a bad move. thanks Razor
