Question on pump harness PAC
GBGN1
stroked
Razor kit.In the wiring harness(controller ) going to the pump there are three wires . Black , red and white. What is the white for? Thanks
Thats the switch that tells the box to change the LED color from red to green.
The white wire attaches to the bare wire inside the pump cable once you strip it.
Thanks, so inside the pump wiring is a red,black and a bare? I only saw the black and red. Someone had areadr cut this one.
Get a razor blade and go back further
Tadahhhhh ;)
