I installed a new cardone hydroboost last week and have 0 pedal. When I pump brakes I can see the shaft through the holes in master cylinder but no firmness. I bench bled the master properly and bled the hydroboost properly. I have no turbulence in brake fluid when brake is pressed. I even disconnected brake line and pressed brakes with no fluid coming out. Can somebody post up a picture of the mating surface between the hydroboost and mc. I have a feeling a rod is missing.
Rich
Rich
