I just put 82 TRSC on the road. Going down the interstate it's turning 2800 rpm's at 65mph. Its got the TH350 trans. It's sucking some fuel. The trans is shifting thru all three gears fine. It's a little early (3rd by 25-30mph). I believe it has the stock 3:08 rear also.
Can someone tell me how many positions the heater fan has. My 84 donor body has 4. I think the 82's have 3.
The idle is dropping off at stop signs and stalling. I turned the idle up a little, it seemed to help, but went back to stalling on the way home from work. It also idles good sometimes and crappy others.
I'm also getting a lot of spark knock, timing is set to 8 degrees BTDC. It hasn't been on the road for several years.
I'm to read up on all the adjustments/tests in my book for M/C, idle, EGR, TPS etc
