Hey guys,
A year or so back I snagged a deal on a gutted hotair intake from e-bay. I never got around to installing it, as I had more pressing things to fix on the car first. Now I'm about ready, but I had some questions I was hoping some of you more knowledgeable guys might be able to answer.
The intake has been pretty much completely gutted: the EGR hump has been completely ground down, the "zip-tubes" running along the sides of the intake to the front have been sealed off, the whole middle part has been opened up into pretty much one big plenum, and the front area, where the flow transitioned from the "zip-tubes" to the center plenum has also been sealed off (though I am unsure if it is still connected to the sealed zip-tubes). The quality of work looks pretty good, the welds seem of a high quality, and so I assume this was done by someone who knows that they were doing.
My questions are:
1) Does anybody by chance know who made this intake? If anyone recognizes the handiwork, it would be useful to be able to contact whoever may have made this.
2) There are several places in the intake that have had holes drilled, tapped, and plugged up with screw-in allen-wrench plugs. They are in the sealed-off zip-tubes and in the front transition area (that has also been sealed off). These plugs have been circled in the attached pictures. when I removed the plug in the front area, there was a decent amount of water inside the chamber. Is there any reason for these holes, and for their being plugged? Is there any reason why there should or should not be water inside these sealed chambers?
3) Before I install the intake, is there any way to get it leak and pressure tested? I'd hate to install it just to find out it leaks boost, or that water leaks from the coolant passage to the intake side, or have it blow apart on a boosted run from a faulty weld somewhere.
I have attached pictures of the intake in question, with some of the plugs circled/labeled. I also included a few sketches I made of how (I think) the stock intake flows, and how my modified one appears to flow, as well as a picture of a cutaway of the stock intake in case any of you guys haven't seen it yet.
If there are ANY questions you guys have, or if there is anything I have made unclear, or anything I am completely wrong on, please do not hesitate to ask me ANYTHING. Any help or suggestions you guys may have on the subject are more than welcome. Thanks in advance!!
Heres the intake:
Here's the underside... you can see some sort of sealing compoung near the rear:
Here are the little plugs into the sealed-off "zip-tubes":
Heres a shot down the inlet showing the removed EGR hump, as well as another angle on the little plugs in the zip-tubes:
Heres the front of the intake, as well as the large plug into the sealed-off transition area (this is the one that had water in it):
Heres an old magazine picture of a curtaway stok intake, for those who haven't seen the inside of these:
Here are some quick sketches I made showing the original flow of the stocker, compared to how (so far as I can tell) my modified intake would flow (grey areas are sealed-off from rest of intake):
My questions are:
Heres the intake:
