Questions on 7th Injector system
M & D Fairchild
How large of an injector can be run before there are any fuel distribution problems, if any.
I am refering to a stock upper plenum equiped with an RJC power plate.
Also have pumps and wiring upgrades to match with any fuel demands that i can forsee for the time being. I am currently running factory injectors that have bin flow checked and they are all pushing the same amount of fuel.
IMHO you could go up to a 50# with no trouble.
If you don't already have the 7th then you should consider changing all your injectors instead of buying a 7th system.
Not saying the 7th system won't work well (I have/use one) but for what they cost a new set of 50# injectors (w/chip) will take care of you to 11.00 range.
Just my 2 cents worth.
The Power Plate is for redirecting air flow, I'd suggest you contact them.
If your trying to just make a point with the stock injectors, well that is your choice, but don't be to surprised about headgasket problems.
I'm running 55s with a 50 for a 7th, and the engine likes it, but there is some odd twists with what I'm doing.
