The transmission is out of the car, it is way up on jack stands, and I want to fix the oil leaks. I added dye to the oil and bought a UV light. Drove it some before the transmission broke. It was the second gear band anchor pin if anyone is interested. Sheared the little piece clean off. Already did the valve cover gaskets. Should I remove the flywheel and check the plug on the back of the block where the cam is? If it is leaking what is best way to repair? Then when I put the flywheel back can I re use the screws? Torque to 60 lb ft? Also, to repair rear main seal, do I have to jack up motor to remove the oil pan? Any tips would be much appreciated. Repairing all oil leaks should be made a sticky. Thanks guys!
