Get a caspers electronics fuel pump, 60 bucks, 45 GPH, which will take you into the mid 11s.
then, borrow a scan tool of some sort from some buick guys around there, or buy one for your own use(good investment)
buy a thrasher 108 race chip for 27 dollars from russ salerno on the internet or buy one used for less.
make your wastegate arm adjustable, for around 2 dollars.
make your fuel pressure regulator adjustable, i found out how to do this from searching the GNTTYPE archives i believe. doesnt cost but a few bucks i believe.
Get a dump tube and replace your cat with this.
buy or borrow some slicks (im sure you have some from your other race cars)
launch with as much boost as you can and run around 21 psi, with no knock. Ebrake launches give you a few more PSI to come off the line.
