Race prepped 8.5 axle assembly
turbodave231
Moderator
8.5 axle with overkill STRONG components.
Moser Spool
33 Spline Moser Engineering axles, 1/2" studs-3" long
C clip eliminators
S-10 wheel cylinders
Aluminum drums
No parking brakes
3.90 gears
With 29x9 tires the 3.90 gear ratio works out to be the same as 26x10 tires with a 3.42. All things being equal, you'll have better 60's on a taller tire.
If you want this axle with a different ratio, I'll set it up for no charge if you supply the gears.
$950 or best, (local pickup preferred, shipping extra)
