black owned
black pride
- Jun 15, 2008
What's the maximum milling of stock heads coupled with the thinnest head gasket to raise comp. Ratio and allow me to run e85?
SignUp Now!What's the maximum milling of stock heads coupled with the thinnest head gasket to raise comp. Ratio and allow me to run e85?
Earlbrown tell me more about the custom pistons
Possible group buy..?Earl I gotta hit you up for a set on an old 109 I have that could use a compression bump.
I as well had earl order my pistons for my stage build which I run 10.5:1 compression and am running e85
Yea they ended up perfect and even with the deck . I’m switching to my stage heads so I’m going to have ether get some new slugs or notch these ones for valve reliefs. Idk though im thinking if I notch these I will gain to much volume and my compression will be to low . I’m right at 10.5:1 right now so what do you think ?I'm still amazed those slugs were possible with both a stroker crank AND a 6.500" rod.
