Ramcharger dual fan wiring harness
oldtimer
Can someone give the color code for the Ramcharger's dual fan set up.
I'm "not" running the stock GN harness.
The Ramcarger's dual fans come with a 3 prong connector
Which wire is for the fans ground, and the other 2 wires ? High ... low ????
I'm going to power it directly from the battery through a relay to fan, and trigger it using the fan wire from the F.A.S.T. ECM.
Thanks a lot,
George
with all the Ramcharger dual fan setups out there, someone should be able to help me out here.
The Turbo Regal Website is down, so I can't search it there, at this time. :(
Someone ????
George
