SignUp Now!Ordered my T with as few options as I could, even tried to get A/C deleteMy 87 has manual seats, manual, locks, manual windows, remote trunk, CCII with non EQ radio, no rear defrost, dual remote mirrors.
I would say a 87 Base regal with Turbo engine, alum drums, alum bumper, posi, radio delete, no power would be rare. I would love to have a light blue one with DK blue int....dream on.
My Gn has 1 option and 1 option only, That my friends is a maplight.
Ok...I have THE rarest option. 87 GN With radio delete AND power antenna!!! Have NEVER seen another like it in 20+ years. Thank you......thank you very much....![]()
Ken B.
RE-Read my post my limited came radio delete power antenna as well. I added the CS2,Radio & factory wiring & speakers.
Ok Brian.........You and I have the RAREST ones then!!![]()
Ken B.
whats the differrence between the 60/40 and the 45/45 seats.. not really sure wich one i have..... does any one have any pics??? thanks.... dont know how rare mine can be......ill try posting up a picture if i can... and also whic one is the shorty console??? thanks
I was told because of the color
heres the options
AR9 seats, reclining bucket
AU3 power door locks
A01 tinted glass
A31 power windows
A90 power trunk release
BD1 rocker panel moulding trim delete
BS1 acoustical insulation pkg
BV8 ornamintation exterior door lock cylinders
BW3 ornamentation extra roof window trim (painted)
BX5 ornamentation ,exterior moulding roof drip (painted)
B24 side window reveal mouldings (black)
B48 trim package luggage compartment
B71 wheel moulding (colored)
B72 ornamentation ,exterior moulding belt reveal (colored)
B77 ornamentation,exterior moulding w/s reveal (colored)
B79 ornametation,exterior rear end
B88 moulding body side (custom)
B89 ornamentation, exterior moulding,RR window reveal
B91 exterior moulding, door edge gaurd (colored)
B94 ornamentation, exterior emblem ,body,var 1
CD4 windsheild wiper system (pulse)
CF5 roof,sun,glass sliding,elec
C18 arm and blade WSW
C60 HVAC system,air conditioner frt man controls
C95 lamp, intr,roof,courtesy and dual reading
D55 console, frt compt,floor
D64 mirror,l/s,rh,sunshade,illum
D68 mirror o/s,lh&rh,rem cont,painted
D71 gear speedo driven
D85 stripe,body side, lower accent
E5Z speedo adapter delete (analog cluster only)
FE3 suspension system (sport)
GU6 axle rear 3.42 ratio
G80 positraction,limited slip
G87 ring gear 8.50 10 bolt axle
J41 brake system,pwr,frt disc,rr drum,cast iron
J5O brake system power
KO9 generator 120 amp
K34 cruise control automatic,electronic
LC2 ENGINE,gas,6cyl,3.8L,SFI,V6,TURBO,H.O
MW9 Transmission,auto,4spd,THM 200, Conv clutch
MXO merchandised,trans,auto provisions,O/D
NA5 emissions system,federal, tier 0
NP5 steering wheel (leather wrapped)
NQ5 cap steering,wheel,horn,deluxe
N33 steering colum,tilt type
N89 wheel" turbo" aluminum
QYH tire all p215/65r15/n wol r/pe st tl HWY
TL6 Grille (black)
TL8 ornametation ,exterior,hood, (3.8 SFI TURBO)
TT5 headlamps halogen 4
T47 HOOD (TURBO)
T63 headlamp on warning provision system
T82 headlamps auto on/off/cont
T83 headlamps,dr,(special)
T93 lamp,tail&stop (special)
UA6 theft detterant system
UQ1 provisions for stereo
US7 antenna,power,painted radio
UW4 speaker system,6,dual frt dash mtd f/d,dual
U23 cluster,inst,trim odom
VD6 bumper provisions,frt,aluminum
VD7 bumper provisions RR,aluminum
VK3 license plate mounting pkg
WO2 package SPORT APPEARANCE
Y56 merchandising package GRAN TOURING
19A stripe color accent two tone med gray met/black
54U Primary color exterior, MED FLAX (91) YELLOW BEIGE
62B Trim comb, light saddle cloth
62I trim int light saddle (I)
I have this also with manual locks/windows and the only option is astro roofOk, my 87 Turbo T has the manual outside chrome mirrors (RPO code DR3). I was told by Kirban himself that only a handful of turbo regals had this option. By the way, I have the wo2 blackout package, which makes this chrome mirror option so weirdCould this possibly be the rarest option for the tr??
whats that^^^^^^t83 and t93?![]()
