84sithlord
- May 3, 2011
I keep going through solenoids. I just purchased one a month ago (or so) and the same thing happened again ( a tear in the rubber end of the actuator). The lastest solenoid worked when i put it in. I use my tr as a daily driver.... i have been noticing my boost going a bit hay wire when i get on it getting on the highway. Could there be too much vacuum that is causing the rubber piece to tear? Any insight will be much appreciated!
