SignUp Now!My first suspect would be the 1/4 tank of gas. I will not hammer on my car with anything less than 1/2 tank since it moves around a lot under acceleration.
My car doesn't like hot weather so I just lower the timing and run it a little rich in the summers and play with it in the mornings.
I see now. The fuel flow obviously is one way but excessive pressure causes a resistance on the pump itself. Going against the flow. Thanks for the clarification.
So I take it, for running high boost, it's the norm to have to replace fuel pumps? Or is there one on the market that's set up to endure the amount of boost I'm running?
Bingo.......a submerged pump will stay cool and perform bettter....put some fuel in the tank first...
The answer to your question is in these charts.
I just reread your parts buildup. You're running 38# injectors with a 60 turbo at 25#'s of boost. You probably need 50's or better at those levels.
I think your fuel level was low enough to the pump could have been pulling in some air along with the fuel and that is what caused the knock. Just go out and try to empty the tank with the fuel pump and a hose; if you don't get a steady stream of fuel, turn off the pump and add a few gallons of fuel and then try it again. If it works fine then you were running out of fuel, if it continues to surge then your pump is probably shot. Your timing may be too much for the weather so if you can take out a couple of degrees, I'd do that. If you can't do that, I'd either drop the boost a pound or two or slightly increase the alky.
Good luck.
I've asked about my injectors in the past and have gotten mixed replies, but most said to "stick with what you've got". FWIW I've only gone a best of 12.61 @ 109 mph with a poor 2.00 60 ft. due to bogging at launch. So there's definitely more potential.
leave the inj alone !! we ran mid 11s @ 116+ (old blue top 36#s) for years with NO alky just race gas.. Now you have alky so it would be even easier .
I wouldn't play around.
If you want to test the pump, jump the relay and run the fuel pressure up with the regulator screw. Should go to 100psi no problem. Yours, I bet falls way short.
