this is the original motor from a 84 gn with 14 bolt oil pan. rebuilt 10,000 miles ago and is still very clean. ran super strong and quiet and has no issues. stock rebuild, but i believe was bored 30 over but i'll have to check when i pull it. 200 miles ago it had brand new valve springs, double roller timing chain set, new cam button, and new oil pump installed. stock heads (no porting), stock cam was replaced at rebuild, has correct turbo crank. will come with timing cover and oil pump still installed. also will come with original oil pan with correct baffle still installed and oil pickup.
needs nothing, ready to bolt on your intake and acessories and drop it in.
$500 located in st. louis, you pick up
