Royal-T-Ltd
- Jul 12, 2003
I need some numbers from some of you who have already been through this.
I just changed the plugs to UR5's gapped at .032 - This stopped my stumbling at higher boosts [I attest that to boost blowing out the spark of my cr43ts gapped at .035] OK Problem 1 solved. Next. I'm new to Alky - Yesterday I would do burnouts and stage - try to build boost - green light - mash on the gas and fall flat on my face. I think I solved that problem. I think to much alky was sprayin in my burn out [Sorry Julio, been procrastinating on hooking up controller wire] so anyway took care of that. Now I was running 21lbs of boost through my 60-1 and V-4. at 45-46 psi f/p. with controller set to about 1:30-2:00. Turbo Tweak chip w/ 19/18 deg. No KR at high gear but EGT climbing fast so I let off before it could reach 1600. Just to play around I turned wastegate 1/2 turn. [which netted more desirable 24-25 lbs] and turned f/p up to 48psi controller set to about 2:00. Had to let off EGT Climbing very fast. ---------- SO HERE'S THE ? I know there are people running a relatively close combo - What f/p, boost, timing...etc. are you running, any hints or suggestions. I would like to be able to run consistantly fast [low 12's-high 11's] and NOT change when I leave the track. TIA
