streetknight
DCVING
- May 26, 2001
Just put the S-10 wheel cylinders and new shoes on the regal along with a Line Lock. Bled the system like stated on gnttype.org. Here...Brake Bleeding, Rear Cylinders, and Linelock Install
Tried to build boost and the rear tires start spinning before any boost builds. Spooned the rear shoes up still no luck. Put it on my lift and raised it up, hold the brakes and as soon as you touch the gas, the wheels turn.
Have went thru the bleeding procedure above MANY times and no luck.
I can build 2 psi with the E-brake, but my other TR with the same EXACT stuff done will hold 13 psi with no E-brake.
Any ideas?
Supposed to go the track in the morning.
Any ideas?
