The passenger side rear brakes do not seem to be working at all. Put the wheels up in the air and power braked it with the wheels turning for about 15 seconds, the driver side drum is hot to the touch, the passenger is cold.
Took drum off, adjusted them out till I could just barely get the drum back on, also sanded the shoes and drum, still will not produce any wear/heat nothing on that side when power braking??
I just bled 3 qts thru the system, but I guess I may still have some air somewhere after installing a proportioning value jumper but the pedal feels as it always has before the jumper install.
Right now the jumper has no effect at all.
Could the wheel cylinder be bad?? or would it be leaking fluid if bad?
