Anyone ever used this ebay kit?
http://www.ebay.com/itm/201541810297?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
SignUp Now!hello people; I know nothing about your question but a vendor should (maybe there is one) sell a complete kit at a price people could afford. I don't race so I don't need the best or nothing fancy just good quality at a price we all could swing.
Also I don't like adaptors but maybe it has to be but a nice simple mounting system would be nice.
Is that too much to ask for or should am I dreaming.
IBBY
Can't tell you about the Blazer rears but I have used the Blazer front spindles and calipers before. Worked out quite well.hello people; Sorry but off the question isn't there a 2wd blazer rear disks that work. I'd like to see a conversion all made from factory parts coming from any make of car. I've seen in most cases factory is better than the aftermarket. Sorry for no help.
Goodluck and you could be the first to try it.
IBBY
Thanks for the input.Never used that kit, but it's similar to the Right Stuff Detailing kit I put on my Camaro. It uses Cadillac calipers and rotors so they are available from a part store when you need to replace. They work adequate for a driver and Inline Tube is a quality company. Looks very complete also.
Sent from my SM-G935V using Tapatalk
Does anybody make a bracket to slip over the axle without having to remove them?
Sent from my LGMS631 using Tapatalk
I was talking to this guy about it and he said " hell you can just cut the backing plate off, ive done it before". That made me think of the bracket w/o taking the axles out ideaYou will need to remove them to get the drum backings off. It is an easy process to remove the axels
Might actually be a good time to check/replace the bearings/seals if it's been a while.You will need to remove them to get the drum backings off. It is an easy process to remove the axels
