With the e-brake equipped calipers, the ebrake mechanism can contact the frame if you're lowered. Mine did when I tried those calipers with a similar kit. It'll depend on where the brackets clock the caliper and your springs. I had to swap out to non-ebrake calipers. Wilwood has a nice set that's a direct replacement for the calipers in the kit (Wilwood par number 120-9333).
Also, the knockback without C-clip eliminators is horrible. Be prepared to go for the pedal and have to pump it a few times to stop the car after going over something bumpy or an aggressive lateral maneuver. If you go for C-Clip eliminators, get the ones with the tapered bearings.
