Rear disk brakes (LS Camaro)
MoJoe
Do you want to put "factory" disk brakes on your rear? I have a complete factory rear disk setup from an LS Camaro (1997-2002). It is a straightforward, nearly bolt on swap. Transplant directions can be found online. Should fit any GM 10 bolt. All parts in picture included.
Includes two of each:
12 inch rotors
PBR calipers with hose(s)... hose for caliper-to-hardline. Axle hardline not included.
stock pads
backing plate with integral drum-in-disk style parking brake, including mounting bolts
axle tube ends ... for flange measurements.
new parking brake cables
new parking brake cable brackets
new SS body-to-axle hose (1)
pair of banjo bolts
$300 includes shipping from Denver.
I was wondering where you got the parking brake cable brackets? and are they also direct bolt on?
Can I get center to center measurement of bolt pattern that bolt parking brake assemble on. Side to side and up and down.
Thanks. Brandon.
