SignUp Now!So what vehicle would i be able to get a 8.5 rear end from.
you don't need to get a bolt in 9" from the "big" names. there are hundrds of shops all over the country that make bolt in 9" housings for the "metric" circle track cars. if you scour the net, you can either find a place to make you a new housing with axles for about $500, or hit the local classifieds and find some local dirt track racers selling off old parts.
someday, i'm going to get a used BGN or Nextel Cup 9" full floater to go in my Monte..
the lower dirt track classes are required to run factory chassis with factory mounting points. some allow a 9" swap, some require that they keep the oem rear axle in it. the G body is the most popular car for these classes due to their cheap availability, strength, light weight, and cheap service parts.Most of those circle track applications dont run a G-body spec rear axle or suspension. Most of the metric frame cars are "front half" cars as far as the frame and suspension go. BGN/WC use something out of the dark ages with the trailing arms from a coil springed 70 Chevy truck. Plenty of budget 8.5 rears out there if you do some scrounging.
Check with TRZ motorsports about their 8.8 Mudstang swap kit I just finished mine. Now I have 4 wheel discs :biggrin:
what years are you talking here?There is one other option you can use if you can find one. The chevelle, cutlas, gs buick chasis use an 8.5 and you will have to bend the outer control arm mounts to make them fit but it will also give you a slightly wider track for the rears. About 1/2" on each side.
the 73 -77 A bodies are way different than a G body, but i know there used to a be a few kits available to put a 64-72 A body 12 bolt in the G body chassis. but they vary from year to year- the 64-67 rears are about 1" narrower overall than the 68-72, but the mounting points are the same frm 64-72. in 67 or so, they changed the spring mount on the axle. there were some BOP 8.5's put in some of the 68-72 Buick, Olds, and Pontiac cars, but they are kind of rare. they also use bolt in axles (a good thing) where every other A body rears used c clips for axle retention.
i still think a slightly used "metric" 9 inch or an 8.5 out of a TR or 442 is the way to go.
