jwillettgn
- Feb 8, 2006
We have pulled the rear end out from under the GN and are starting the upgrades. What we have is Moser 30 spline axles with a new Eaton 30 spline posi unit, 1350 yoke, HR parts suspension, a T/A Performance rear cover, and stud kit for the carrier bearings. We are looking at the C-Clip Eliminator Kits and not sure which way to go. When I pulled the drums off they are toast and we will need new ones so was thinking about converting to disc brakes while I had everything out. I read somewhere that after some disc brake conversions you do not need C-Clip Eliminators. What are my best options? I am also not sure what wheel stud size I need for the Moser axles or if I should up the size. ½” X 3” close to stock dia. or 5/8” X 3”. Thanks for any input.
Jim
Jim
