tim87tr
Obsession or Digression?
- Sep 19, 2001
I just reinstalled the rear main seal. The original had been replaced just a few thousand miles ago with the neoprene one by the previous owner (actually I think hired out). I believe that the bad leak may have resulted from silicone used on the rear main seals themselves or the stock side seals?(black) being reused in the previous repair.
My question is the side seals. I installed are the white ones that expand when in contact with oil. I opted to use these instead of RTV in the side channels, although I did place the RTV along the vertical cap sides/block mating surface. But not in the side grooves. The side seals stick out a quarter inch into the pan area and it says not to cut them off. I will have to since they would hit the pan. I knew they were longer than the cap before I installed them. Maybe this is a universal kit and works that way with other 3.8's. But has anyone had any experience with these longer seals?
