i cut all four pieces @ 26" on mine and whatever i had extra on each piece i sort of cut two angles to make a point which made it squared when installed...that sounds confusing but just cut 4 pieces 26" and your going to need to flatten a good amount of the end to clear the trunk springs at the top if your using 3/4" conduit....i spent an entire day on this job...heres my advice
1.goto home depot and get 10' 3/4" conduit, (6) 3/8x1_1/2" bolts, (6) 3/8 nylock nuts, (6) washers, and i bought some drill bits as well and a new hacksaw blade....
2. it was impossible to do the job w/o removing the back seats...i can't see it being done....i tried b/c im lazy but gave in and took them out...just make sure your have a torx #45 to remove the seatbelt/backseat bolts...i didnt
3. i drilled the 6 holes before jacking the car up
4. i then flattened the ends of the pipes about an inch for some test fitting....i later had to flatten them more to clear the trunk springs...
5. i then bent the pipes the best i could to make them roughly fit the way i liked...i used a pipe bender(borrowed)
6. jacked the entire car up...i didnt know only the rear needed to be up
  and i have a rock driveway so it probably was more level on the ground
7. got a ruff idea of were to put the holes and drilled one at a time put the bolt through it in the car then marked where to drill the other hole...
8. repeat steps for all pieces and to save time start with the straight pieces and do the bent pieces last which i did not do and made more work...then i installed them w/o washers so dont forget the washers either...now your seeing why this took all day
9. tighten the b!tches up and clean up and lower the car...by now your prolly so fed up with this job your saying "i swear if i hear one more squeek after all this work im drivin off a cliff"
10. admire your work of art
Here's My Install...warning: BIG pic
