So let me just start out with my suspension setup:
SPC springs (car is at least 1.5" lower)
Bilstein HD shocks
Energy Suspension body mounts
UB Machine front UCA's
Stock rear UCA's and LCA's that are boxed and have HR Parts N Stuff greasable poly bushings
S10 Blazer 4X4 2dr rear sway bar. It bolts to the rear axle and the endlinks mount to the frame. (Poor man's HR bar)
Rear tires are 255/50/16 Kumho Ecstas (hard compound)
Obviously I set my suspension up with handling in mind, and it handles fantastic and rides sooo nice. The only problem is that when I give it throttle and it hits 2nd gear the rear tires break loose in a bad way. That's only 1/4 throttle and 10psi of boost. Of course the tires may be the main issue and some DR's would help, but I'd like to optimize my rear geometry and see where it gets me.
As it sits now my current pinion angle (in relation to the driveshaft) is about 0 to +1/4 degree. I don't have any airbags installed at this time.
Other than getting my rear pinion angle to -2 to -2.5, what else can I do? Are there any control arm relocation kits that will help?
Keep in mind that I like my suspension setup, so drag shocks or lighter springs are not in my plan. I don't care about getting an insane 60ft out of it. I just want to get the rear to plant a bit better so my car is not a total death trap.
Thanks!
Bilstein HD shocks
Thanks!
