The Granny
- Apr 19, 2014
I recently had some work done on my car by Madman Racing, I had new axles, posi unit, wheels studs, and a few other misc. items installed. When I picked up the car from him, I took it to the track the next day. Per his instructions, I broke in the new posi unit. I heard a screeching noise on the way back to my trailer after the first pass, and called it quits and loaded up and took it home. I jacked up the front end, spun the front wheels, and they did half a rotation. The front calipers were grabbing onto the rotor for some reason without me pressing on the brake. I got new calipers, attempted to bleed the system (power master) myself but couldn't get fluid out of the rear bleeder valves. Took it to another shop, Century Automotive (owned by Mike Kurtz) a few days later to have them attempt to bleed the brakes.
What he told me is the proportioning valve was stuck shut, so they removed it, cleaned it, and put it back in and the system bled just fine. Charged me $120 for it
Got the car home, as soon as I put it in park, I got a huge transmission fluid leak. I found the source to be a loose cable in the back of the transmission (maybe speedo cable? 200r4 trans.). Tightened it up, and since I had the car on Jack stands I figured I'd start the car and cycle through the gears to check for any leaks. Ran through them just fine, no leaks, but my father who was outside the car watching for leaks saw the rear wheels spinning and told me to put my foot on the brakes. I did and they still spun. I mashed the pedal down and still no change in how fast the wheels spun.
Could it be the proportioning valve stuck shut again, and it's not allowing any fluid to the rear drums? Not too sure of what it could be... Im not blaming anyone and don't want to sound like one of those "ever since you worked on my car it's done this" type of guys, I just want my brakes to work [emoji23] Huge thanks in advance to anyone who can help me out with this.
Giancarlo
Giancarlo
