So the block, pistons, connecting rods, crank, heads and intake are at the machine shop and most of the parts exept for the turbo and trans cooler are in. Just wanted to get some opinions on what, if anything i have forgot. The reason for all this was a blown head gasket and once my mech starting pulling everything apart found the block was .60 over and turbo was damaged. Heres a list of things going into the build.
.30 block(used)
.20/.20 crank(used)
forged pistons(used)
connecting rods(used)
heads are getting ported along with the intake to match
New ARP Head Studs
New 210/215 roller cam kit
New PTC 3000 stall converter
New PT6262 Journal STD Act E cover .63 turbo
New Crank sensor
New Plug wires
New Coil pack
New Oil Pan Gasket
New Trans Cooler
New TR Regal Turbo Protector and Oil Drain Kit
The stock driver side manifold has a crack as of right now im on the fence on weather to repair it or go with a set of Hye-Tech Headers
FMIC and Aluminum Rad were already in the car before the head gasket blew, along with couple other things on my sig. Right now the car has 42lb injectors and im sure ill be needing to purchase some 60lb ones if i want to up the boost. The car also has alky. Anything else i might want to look into getting? And what are you guys thought on the build?
I was also running 24lbs of boost with the ta-49 with zero boost and damaged compressor wheel in that same turbo, who knows how long i was running with it like that.
.30 block(used)
.20/.20 crank(used)
New ARP Head Studs
New Crank sensor
New Plug wires
New Coil pack
New Oil Pan Gasket
New Trans Cooler
