Rebuild Issues
gpcrisp
I recently completed a rebuild on my transmission and am affraid I may have overlooked something. I installed a Transgo Master kit and Level 10 Hydrosystem Valve Body Recalibration kit. I have reverse but no forward gears at all. So before I tear it down again I'm hoping for some input as to what I should look for. Did I miss something in the Valve Body that is preventing the forward clutch assembly from engaging or ???. Any help would be very much appreciated
I should have searched the post's before asking the question. I found this "ok, first, no sun gear in front planet would do it. cut or not correct, or not there, rings on forward drum shaft would do it. ah,,, cracked forward piston would do it, manual valve is flipped over on s clip would do it. ah.. govenor o ring or govenor NOT THERE would do it. gov cover bolts loose would do it... govenor gear not there or stripped or broken would do it. Input shaft od sprag failure would do it too... thats all I can think of right off.
Marks deal is something broke...your deal is something was either left out or assembled wrong Either guy, both problems suck!" but any other info or suggestions would be appreciated. Thanks
